Heat Acting up | Ford Explorer Forums
Heat Acting up
NorelNBFD
East Meadow, NY
1998 Sport
My 98 sport's heat is acting up. basically when its on outside air(not ac) it starts off cool, but gets really really hot. if I put the AC on , it takes a while be eventually it gets ice cold. If i turn the ac off, it goes back to red hot... any ideas on what could be the problem?
Sounds like a problem with the temperature blend door. It works on vacuum. If you have a leak in the line, it could be taking a while for the vacuum to build up and move the door to cool. What happens if you have it on MAX a/c. Does it blow cold immediately, or faster than if in regular a/c?
AC takes a while, say like a minute or two, but it eventually comes out cold.. no real time diffrence between regular ac and max ac
