IronTooth
- February 5, 2010
- Albion, NY
- 2000 XLS
2000 Explorer XLT, 212k odometer, 4.0 OHV engine, 4WD
Symptoms:
1) Loss of heating efficiency from heating system - over a couple of months - to the point where there is virtually no heat coming into the vehicle at all, even at maximum temperature setting. #Until recently, I was thinking that it was my imagination, coupled with colder weather, but about two weeks ago, over a period of a couple of days, lost heat entirely.
2) Loss of coolant.
Additional Information:
A. When climate control (heat/air/defrost) is set to heater, and regardless of the temperature setting:
#- Coolant loss is accelerated, about 1 quart a week (figure 250-300 miles per week);
#- Engine temperature gauge will run slightly lower than normal, and shortly after acceleration, it will deflect slowly a couple of times about half way down toward the 'C' mark and back up again;
#- when stopping at a traffic light after sustained speeds over 40mph, and immediately after turning the engine OFF, there will often be a fairly loud, but diminishing bumping or thumping noise from the front of the vehicle (BUMP, Bump, bump...) at about 1.5 second intervals;
#- Coolant does not drain back to the radiator from the overflow tank.
B. When the climate control switch is set to 'OFF':
#- Coolant loss stops or is minimal, and coolant is drawn back into the radiator from the overflow tank;
#- #The engine temperature gauge, after initial warm-up, is steady at the 'normal' level for #this vehicle (centered on the icon), regardless of engine load;
#- I will sometimes hear a burble sound after the engine is turned off, which I am interpreting as the sound of coolant being drawn back into the radiator.
I see no obvious leaks in the engine compartment, especially not around the heater hoses or connections. #
There is no obvious (to me) odor of engine coolant when the heater is on, and no obvious unusual wet spots on the rugs. #I have not tried to look under the rugs for stains, though, so can't rule out a heater core leak.
Oddly, just about the time that I lost all heat, the engine threw a P0171 code.
Thanks for any thoughts for a cause or recommendations for further troubleshooting...
Symptoms:
2) Loss of coolant.
