2000 ford Explorer charging system woes | Ford Explorer Forums
Brokenrod
Rockford, Il
2000 Ford Explorer Vin "E
Hi, new member here!
I recently inherited a 2000 ford explorer SOHC, Vin "E". I'm having issues with the charging system. When i got the truck about 2 months ago, it had a bad alternator ( parts store tested and confirmed). I didnt have the cash at the time, so i went to the junkyard and thought i got lucky by picking an exact match that looked darn near new, it was still shiny! ( I know that you cant tell if it works by how clean it is, but hear me out).
All was fine until the other day on my way home from work, the dash battery light popped on and the gauge started draining. connected the meter, and sure enough, the alt is not charging. Battery is confirmed to be good with no dead cells. I did a little online research and backprobed the voltage regulator plug. The yellow wire has 12v with key on, but the green/red stripe wire that should have one volt with key on has no voltage with key on, or while running. Checked the appropriate fuses and they are good to go also. megafuse also has continuity between posts.
Where do i go next? As i stated in my introduction- Electrical troubleshooting is my weak spot. What does the green/red wire connect to?
Thanks for any info/ help.
The B+ wire(big one on the post) should have 12v on it at all times. Make sure fuse 14 in the battery dist. box is good as well.
