SJCharney
- June 23, 2015
- Lehigh Valley, PA
- 2011 Ford Explorer Limite
Need help. My wife's 2011 Explorer Limited v6 AWD will not start. The battery was low in it and pulled it from the car to charge it. After charging and load testing it, I determine it was bad and replaced it with the factory Motorcraft 65-650. BTW, the battery is good and the alternator is fine. Once in the car, the car will not start at all. This is what happens......
With my key fob in the car, I brake the brake to start it. Right away it goes to the auxiliary power mode and gives me a message to press on the brake to start. When I press the brake and push the start button again, the car still does not start. The dash and the computer now thinks that the car is running though and then rolls off of bunch of error messages in left side screen. Low oil pressure, overheating, low fuel pressure, check AWD, trac error, and then finally a "Starting System Fault". Additionally, the check engine light, brake light, and the other light up warning symbols on the lower right side of the dash cluster are lite. I have check the the fuses under the dash including fuse #18 that is a 10A and they are all fine. I have also check the fuse and breaker panel under the hood next to the battery. The 30 AMP breaker associated with the PATS and other systems that could impact the starting abilities is fine. The battery cables are clean along with the terminals. the secondary plugs and connection to the battery terminal assembles are also clean. I have disconnected the battery twice (negative first then positive) in the hopes of re-setting the PCM with no success. Tonight I am going to disconnect the cables again from the battery and run a earth ground from cable to cable in the hopes of draining all power from the system and re-booting the PCM. What else can I do to fix this? I am going to buy a new ODB II scanner and reader now. I have had so many problems with this truck since new and it is only at 78K miles. I need help
