eherna
- July 19, 2007
- Guaynabo, Puerto Rico
- '97 XLT
Let me introduce myself. I am a 51(close to 52) year-old male. And the reason
I'm here is because I have two Ford Explorers, one 97 and the other a 00. So
you can all see I am a reincident on this Explorer thing. Well, going straight to the matter at hand, the 97 Ex started to develop a peculiar behavior. At first, the only symptom it had was a sudden loss of power(and speed) when traveling between 50-60mph. It was not so bothering because all you had to do was to ease on the gas and then resume(sort of a little ''pumping''). But recently the thing got worse. Now It feels like one piston is loosing power, either current or gas-air. The codes came out: P0303 and P0305. So, I decided to change the plugs and wires as there was no other indication except for those two cylinders misfiring. After that ordeal of hours at reaching things with just your fingertips and back-stretching positions, the job was done. During this procedure, I started the engine after each plug/wire change so I would detect anything that changed. After I changed the first one (#5, I think.-It it the middle one on the driver's side), I thought that the problem was over. But never went inside to feel the truck from the drivers seat. All I did was turn it on(from the outside thru the window, not even seated) and give it a little race turning the throttle. So, the surprise was when I finished and seated inside. The ritmic feel of a piston misfiring was still there, exactly the same as before. So, next step was in the same direction. I swapped the ingnition coil from the 00 Ex on to the 97's. No change. I even tried swapping the PCMs (or ECMs) but they were different numbers and the 97 didn't even start. So, here I am, at the beginning, but at least I have tried the MAS, IAT, and TPS (using the ones from the 00 Ex). I NEED HELP. Can it be the control module(PCM/ECM) or the injectors (#5 and #3). I have erased the codes more than once and only those two come back. One of these times the code for #2 came out, but always with #5. The injectors are ~50$ each so I am not too willing on spending 300$ just to see if something changes. I also was considering on buying a gas pressure gauge, which is a lot cheaper and check the pressure at the rail before actually going to attack the injectors. What do you guys think?????
