hello looking for help | Ford Explorer Forums
jcarnes2
Sidney,Ohio
I got some codes given to me not sure what they mean or how to fix them and I need some advise.
B1834,P0500,B1410,B1475
I was told they are body codes but don't know past that.
C1230
Told ABS codes
B1941,B1869,B1994
Told air bag codes
P1151,P0171,P0174
Told engine codes
Any and all advise and help is appreciated.:D
Thats a lot of codes! Think I would take the negative lead of the batt for 20 mins and then put it back- start her and see what codes you have after a short run..... any that still exist need looking at closer!
p0174 and p0171 are lean bank - indicates inlet manifold seals letting in air...makes mixture lean.
I am sure if you do a search with each code on its own here you will find what they mean.
welcome
thanks
thanks for the input friend of mine said it was the mass air flow sensor
