Oldman
- November 26, 2006
- raleigh, NC
- 92 Sport, 94 XLT
92 Explorer Sport - Rear only antilock brakes. I'm at the end of my rope. My 92 Sport's antilock and brake lights have been on for awhile now and have just about replaced everything in the system. The brake control module, antilock brake valve, blead the entire brake system, checked the resistance on the rear axle sensor and cleaned it. Have checked for voltage at the antilock brake valve and it has around 1.5 to 2 volts on 3 pins and 5 volts on 1 pin. Ever since this light problem has started the brakes have worked fine except the rears will lock up if you nail the brakes. Also have pulled the fuse for the control module and the brake light will go out but not the antilock light. Unplug the control module and both lights go out. I want to keep this 92 and would like to have everything working properly. I have two Explorer Sports, a 92 and a 93, and have decided to sell the 93 since it is has a standard transmission that my wife and daughter do not want to drive if their vehicles have a problem. Has anyone out there had this problem before or know of a solution to it? I could just unplug the module and say the he...with it, but I do not care for the brakes locking up and flatspotting the tires. I would really apprciate some help on this one.
Thanks, Oldman
92 Sport - 132,000 mi
93 Sport - 123,000 mi
Thanks, Oldman
