!!! HELP !!! Changing front rotor | Ford Explorer Forums
phoeneous
Vegas
1996 XLT
Ive managed to do all of the following:
1. Removed caliper, pads and clips
2. Removed rotor cradle/bracket
3. Removed cottle pin, lockring, outboard washer and bearing
4. Removed grease seal and inboard bearing
Theres one last piece on the old rotor and I have no idea what it is. Obviously the new rotor doesnt have it. It looks like a slotted disc that is pressed on to the rotor but I dont know how to get that sucker off. I think Autozone may have given me the wrong rotor. Heres a pic:
looks like the abs/vss sensor ring
one question, this is a 2wd Explorer right?
My Ford manual doesn't show that piece. Compare your rotors with other ones for a 2wd explorer.
edit: It is a Front brake Anti-lock Sensor indicator 4x2 Ford part #2C182
you didnt get the right rotor for your ex. Mine is a 2wd and has those same rotors in the front. That is a ABS sensor wheel. You have to get a rotor that already has that sensor wheel installed.
Yup, wrong rotor. I took it back and got the right one. Of course they cost more...
Those two bolts that hold the caliper cradle/bracket in place are so hard to get off!!!
Anyway, everything is back on. New rotors, new pads, new hardware, new grease seals, new grease. Works great!!!
not with air tools :)
air tools really do make life SO much easier =]
