cookiedoh
- May 8, 2008
- Portland ME
- 1998 Sport
Having trouble with 1998 Explorer Sport 4.0L 4x4 transmission. It's real sluggish in 1st gear. There's some wierd shifting near 2-3 or 3-4, not rough just back and forth a few times. Check engine light is on, giving the following codes:
750 Shift Solenoid A Malfunction
1762 Transmission system problems
1405 DPFE Upstream Hose Off Or Plugged
My mechanic said it has no first gear, hence the sluggish. Ths sluggish first (or 2nd?) was intermittent and seemed to be more often when it was warmed up. Now it's alwasy sluggish. Changed the fluid and filter 6 months ago when it first started. To clarify, I just drained the pan not cooler, etc.
Could it be something simple like a control module or is it time for an overhaul?
Vin 1FMYU24X7WUB81590 incase that helps.
