smallblock1985
- December 10, 2011
- Jacksonville FL
- 1999 Ford Explorer
When the car is moving forward and you make a turn the front end begins to shake/shutter. If you sit with the car in park and turn the wheel from side to side the issue is almost non existant. It seems to only happen when you make a large turn such as turning into a parkng lot, so when you make more then a 10 degree turn for example. If Iam driving straight there is no issue and the problem seems to be intermitent, sometimes it it will act up other times it wouln't. There is no issue with the motor the car idles and drives fine, it only shutters when you make a turn. I believe that it may be the power steering pump because it seems to happen when you put more strain on the pump. Any ideas or suggestions?
1999 Ford Explorer 4.0 V6 2WD
165,000 miles
165,000 miles
