help!! driver power window prob | Ford Explorer Forums
lumpydump
northern california
2002 xlt
have 02 ex. and the driver power window is all the way down and when i hit the switch to roll up nothing. took door panel off to check and stuck a test light on switch which is working and put the test light on the wire going to motor and motor getting power hit the down button and hear the motor go on but the up switch nothing. all other windows working fine any ideas
same here! Help!
if the motor turns and the window dont move sounds like you need a regulator cuz the wires might screwed up or something. if it doesnt turn at all its prolly binding within itself. my cheap fix is to hold the window button in the up position and hit the bottom of the door near the window motor.
Here is a great link for electrical troubleshooting for the windows, thanks to theofam for this great link:thumbsup::thumbsup::thumbsup:
Dead Link Removed
Hope this helps out! :salute:
