- August 26, 2004
- West Virginia
- 1993 2dr
On new years day some friends and I did some wheelin in the snow, which quickly turned to mud, which meant I had to 'get on it' a little more than normal in some areas. I noticed towards the end of the ride I had a noticeable clunk when flexing hard or hitting big bumpes and dips. It sounds like its coming from under my dr seat, or right behind the dr seat. First thinkgs I check are the RA bushings. took off the bolt, took the bushinges off, no splits, holes in bracket are solid. front driveshaft u-joints are good, rear leaf springs are good, mounts are good, rear driveshaft u-joints seem fine. So I'm stumped...
My dr front ball joint does need replaced but I'm not getting the noise or feeling under the seat unless I'm cutting hard to the right and the rear of the truck flexes or I hit a bump or dip. Any idea what this could be? tranny mount? ball joint? idk..
I'm taking the truck on a benefit run this sunday, mild trails but still would like to get a look at something tomorrow and would like some pointers since i'll be working outside in 20 degree weather.
