SCB2525
- August 5, 2006
- Richboro, PA
- 1996 XLT
A couple months ago, I developed an issue where the parking lamps would only work if you switched them to halfway between the parking lamp and headlight position. Then, the dash lights started to blink out randomly with the headlights on which would be fixed by fiddling with the switch a bit. Tonight, when first starting out to return home from a friend's house, I have nothing but headlights when switched in the headlights on position. No parking lamps (which should be on with the headlights), taillights or dash lights no matter how much I fiddle with the switch. With lots of fiddling, it also seems that with the ignition completely off (but I didn't try it without the key in the ignition), if I turn the headlight switch a certain way, it turns the idiot lights and gauges on the dash on and turns on the fuel pump like my key is turned to ON.
WHAT THE HECK? I really need to get some input on this as I'm going to be resigned to driving during the day only until I can fix this. Everything points to a bad switch to me except WHY would turning the switch a certain way turn the fuel pump and gauges on?
