BrianDye
I'll have another...
- March 1, 2009
- Monroe, MI
- 2006 XLT
I am using a friends pair of projectors he never ended up using. His truck had separate high beams, so this wasnt an issue for him, so he has the regular harness.
Our Explorers (Well, 1st, 2nd, and 4th gens) use one bulb as low and high. Problem is, if I flick my high beams on, the cutoff shield will rise, BUT the low beams will turn off, turning the ballasts off.
I read online someone said wire a diode in between the low/high beam wire on whatever side you use as the input to the HID harness. Everytime that was mentioned, that was all. Nothing about how, or where or what type. I can wire things good, but when it comes to electrical terms and little gadgets, I get lost.
Can anyone explain what diode I would need, and would a store like RadioShack sell them? I would need just one I believe, right? Thanks in advance!
I figured out how it works, but im stumped as to what one I need. Ill only need one because the harness that plugs into the TRS harness only needs one input anyways. It wont actually be carrying the amperage of headlights, so I dont need a high amp rated one, right?
