HELP!! IT JUST STALLED | Ford Explorer Forums
mgv366
long island,ny
'05 Sport Trac
i have a '94 XLT with 115K. Have had no problems until yesterday. On the way home from work while moving about 35 mph in moderatre traffic with outside temp around 65 deg F I went to give some more gas as traffic was opening up and just like that the damn thing shut off.
Pulled to the side of the road, put it in park and tried to start again. Enging cranked fine but would not start?? waited about 30 mins tried again no luck. Tow truck came and towed me about 2 miles to a parking lot so I could come back in the morning and attempt to fix. As I was putting the windows up to lock up the car I figured why not try starting it again. And just like nothing it started right up!!! So I figured why not try and get closer to home and low and behold the engine ran perfectly all the way home??!?!?!?
DOES ANYONE HAVE ANY IDEAS AS TO WHERE I SHOULD START LOOKING THIS WEEKEND FOR THE REASON THIS HAPPENED?????? THANKS...MIKE
My first thought is a bad electrical connection somewhere. I'd start by carefully inspecting the wiring and connections going to the fuel pump, and then the ingnition system.
Could be something as simple as a bad fuel pump relay.
