HELP, it won't shift!!! | Ford Explorer Forums
crice
Smithville, MO
1994 Explorer Eddie Bauer
:help::help:
Hello,
I have a 1994 Explorer Eddie Bauer, 4.0, 4x4, auto w/ OD, 184K miles on second transmission. Now it has started again....!! It will act like it doesn't want to shift. When I start from a stop it will not shift up through the gears unless I play with the accelarator/RPM's. I let off the gas once or twice and then it will shift. Once I get it up to speed, it seems to shift up and down just fine while driving down the highway but then will start all over again when I have to slow way down or stop. I love this thing but don't want to spend another $1500 bucks to keep it on the road again. I have already done a fluid flush, replaced the filter and pan gasket but no luck. I took it to a transmission shop and they said they tested the vaccum and that the issue is on the inside and it would have to be rebuilt or replaced. I drove it 35 minutes to get to the transmission shop so it seems kind of crazy that I have to go through this all over again. I'm not too much of a mechanic and could really use any help you guys have.
Thanks so much for the reply! I would love to do that stuff but I don't know how. Is there anything here on this site that would tell how to do that type of work?
Thanks,
Chris
