mcompton1973
- June 22, 2003
- Walnut, IA
- dunno yet
My moms 2008 Explorer XLT 4.0l with 135k miles
Symptoms:
Started out as an occasional rough idle...mainly at idle
A couple of times the engine temp has gone to hot...always at idle
some coolant loss
Steps I have taken so far and observations:
I am just starting to try and work out what is going on. Pulled codes...no CEL on...had a code for intermittent misfire. I am assuming this is a byproduct and not the root problem. I will check and deal with things like plugs, wires, coils once the cooling issue is resolved if it comes back.
No sign of water in the oil
with cold engine, there was no fluid in the overflow container...nor was there VISIBLE fluid in the radiator. I added plain water to both and started engine and let it warm up.
I tried to squeeze top and bottom radiator hoses as the engine got to temp. Neither gave me any indication water was moving through them. Neither felt hot to the touch at all.
There might have been a little leaking on the very top of the radiator under the overflow bottle...but not certain it was leaking, or just leftover from filling them. Went back a day later and does not appear to have been any water loss while siting. Did not start it again until I get some advice of where to go next.
Heater on high, air was not really warm, but if I gave the engine some gas it got HOT....let it go back to idle and it cooled off again.
There is something floating in, and on sides of the overflow bottle. Almost looks/feels like dirt. Has a coppery color in the tank, but I rubbed some between my fingers, feels like dirt...not really metallic.
After engine was warm...seemed like ho heat at radiator. I removed cap and water in there was not hot at all.
Preliminary thoughts:
Kind of thinking that it might be a stuck closed thermostat. This is not my area of expertise...but wouldn't that explain why it doesn't feel like water moving through hoses? If so...any thought what the dirt/shavings looking stuff might be? Would the same symptoms be a result of a clogged up radiator? Is that even a thing?
I hate to just throw parts at it without knowing what is the actual issue.
Symptoms:
some coolant loss
