z71bam
- September 25, 2010
- HOUSTON
- 1996 XLT 4-dr 2WD
My 1996 Ford Explorer 4dr XLT with 4.0 OHC V6 is having an engine issue.
Whenever I start the engine, I feel abnormal shaking from the engine... as if one of the pistons is hesitating or sluggish.
Typically, I'll let the engine idle for about 10 seconds and it stops, but I once tried driving with the shaking and the *Check Engine* light came on.
I had the light checked and it returned [CODE P0303 3rd cylinder misfire]. I was told it's probably the plugs and/or wireset. The wireset is original and the plugs are 10 yrs old, so I had replaced them.
The explorer ran fine for about a month and now it's shaking again upon starting.
What do you guys/gals think the problem is and your recommendation? Thanks in advance.
