DocVijay
Meow
- February 8, 2001
- Tampa, FL
- 1999 Sport 2WD
OK, I went to the shop that's going to install my lift kit. I have the 3" ProComp spindles a double add-a-leaf (+2 leaves per side) and some Warrior shackles (figured I'd rather have it all in case I needed it). Anyhow, I thought about doing an SOA in the rear and the spindles and a full TT in front. The mechanic said that that might be too much lift in the rear; he estimated about 6". The rear of my X still looks saggy even though I switched to the 4dr leaf pack. I'm thinking that even with 6" of lift, it would end up being only 5" because of the sag. Then a 2" TT would give me about 5" up front (+/- to level).
I ordered some ProComp 33x12.5 17" All Terrains to put on the X. Would they fit if I just used the spindles in front and then the a-a-l and shackle in the back? I could use the TT to even it out afterwards. They seem to think that the a-a-l and the shackles will give 3.5 to 4" of lift. What do you think? Which way should I go?
BTW, this mechanic of theirs is pretty damn good. I'll try and take some pics of the trucks he's built, pretty impressive. Some daily drivers and also some real off-road monsters with 15" of travel, etc...
I'm going to have this done next weekend. What do I do? I thought I knew, but after talking to them, I'm more confused.
