Keith in Mich said:
Soory on lunch in a hurry car in question a 1992 ford explorer.
That's all good, but you forgot to include 2 wheel or 4x4? Manual or auto? 4.0l OHV? But I'll try to help. All values are
pound-feet unless otherwise stated, from the Haynes repair manual:
flywheel/driveplate bolts, step 1= 108-132
in-lbs
flywheel/driveplate bolts, step 2= 50-55
transmission to clutch housing= 18-38
mount to crossmember nut= 65-85
crossmember to frame nut and bolt= 65-85
automatic transmission to engine bolts= 28-38
torque conv to driveplate nuts= 20-34
neutral start switch= 84-120 in-lbs
clutch pressure plate to flywheel bolts= 17-23
release cylinder to clutch housing bolts= 13-19
drive shaft to xfer case bolts (4WD)= 12-16
driveshaft to rear axle with double cardan U-joint=70-95
driveshaft to rear axle with single cardan U-joint= 8-15
driveshaft to xfer case flange bolts= 70-95
driveshaft to differential yoke bolts= 120-180 in-lbs
