dsfii93sport
- August 11, 2004
- Indy, IN
- 93 Sport
Ok, I just got a new tie rod end today for the outer driver side (well got both but working on Driver side today) but I am sorta lost and wondering if I got the wrong part?!
The replacement tie rod end ball joint came w/ a seperate rubber boot?! I thought this was supposed to be already connected to the tie rod joint to hold grease? This is a little different then Im used to on GM cars where the ball joint is one unit w/o the grease port. Also the darn gream ports that came with it are seperate,,, and where does this screw in because the hole on the top of the ball joint is not threaded!@! Eiks,, this is different... Did I get wrong part?
