Chris Harrach
- May 6, 2010
- Atlanta, Ga.
- '97 Eddie Bauer 4WD
Is there anyone who can tell me in what order to install clutch pack? What I have is as follows per side:3 clutch shims marked .030, .035, .040. 4 clutch spacers. 3 friction plates. A total of 10 per side. This kit is from Ford Racing. (Kit # M-4700-B) which I got from Summit Racing. I've no idea in what order these go in, and the only instruction sheet I was able to come across on this forum was an excellent & very informative 8.8 Traction Lok differential rebuild by Roadrunner777, done in November 2011,showing the old and new way to install, but those instructions (both old & new way to stack the clutch pack) had 8 instead of 10. However I did see a very good YouTube video on this installation. I'm guessing that from what I've gathered, I need to eliminate one clutch spacer per side, and one shim. Also, there was a lot of confusion as to whether or not I had the correct "Spider Gears". I purchased a set from Allen Vigil Ford in Fayetteville. When I opened the box, the gears had one less "Tooth" or Cog than the ruined set I removed from my differential. (My side gears had 14 & the new ones had 13. The same thing with the small upper & lower gears: Mine had 10, the new ones had 9.). I went back to the dealer & was told that this was a design change from the original, apparently the 2nd or 3rd, and that the gears were correct and would fit. Has anyone heard of this happening? Although Im figuring a lot of this out as I go along, Id love to hear from anyone who could shed some light on this. Cheers.
