Help!! Oil "gauge" reading zero. | Ford Explorer Forums
427435
Rochester, MN
2003 Eddie Bauer
The vehicle is a 2003 Ford Explorer EB with the 4.6 V8.
I figured it was the sender. I replaced that and checked connections. Still "gauge" reads zero. Removed sender and used air pressure to check the sender (off the vehicle)----sender OK.
What else could the problem be? I've got oil pressure as I driven it 100 miles with the zero reading and it runs fine without any lifter noise etc.
Anyone run into this?
