z71bam
- September 25, 2010
- HOUSTON
- 1996 XLT 4-dr 2WD
I have oil (dried, crusty, burnt) in the rear passenger cylinder spark plug well which is causing severe hesitation and shaking from the engine of my 1996 Ford Explorer 4.0 OHV V6. I believe the engine is also burning oil because it appears about one quart low, and this vehicle has never leaked oil before. The check engine light code says the cylinder is misfiring.
If I take the valve cover off, what should I look for to determine the problem?
What do the Explorer Geniuses suggest as a solution to fix this problem?
THANKS IN ADVANCE!
THANKS IN ADVANCE!
