ROBinGa
- February 16, 2014
- Ga
- 2003 Explorer XLT 4x4 4.6
My first post...I recently changed the spark plugs in wife's 2003 Explorer 4.6 which has 128,000 miles. We had service engine light to come on and codes using Advance Auto store tool I borrowed showed P303 and P316 and P171. Helpful guy in the store pulled codes and it indicated a cylinder misfire and he said he would change all 8 plugs and see if that corrected issue. If that didn't then he suspected the ignition coil for that cylinder to be bad. So I changed the plugs with Motorcraft SP 493 and used anti seize on threads and dialectic on plug boots as suggested. While taking out plugs on driver side, the third plug in from front end was covered and I mean covered in oil. I cleaned boot and tube as much as I could and put new plug back in that cylinder along with the other 7 which were trouble free. Nervously cranked the engine and it ran well. Service engine light went off the third time I cranked it and is running well and stronger I think. So I think that is cylinder #7 being third back from front on drivers side. I reported back to my guy at Advance Auto and he said the oil in that spark plug tube is a leaking seal and I need to address right away. He said I could do it since I was able to change plugs but it would be time consuming. But now that I am researching I do not find spark plug tube seal part nor any info online about such a job. Anyone ever had this issue and changed out the spark plug tube seals? Or is it the valve cover gasket? Any comments appreciated.
