Help on DVD player install.. | Ford Explorer Forums
MaxeLL97
FortLee, NJ
2000 XL
I just bought a DVD player for my LCD in dash screen but i can't seem to get the installation right. Since i can't seem to post the diagram here, i'll try and explain what it says, i just need help with two of the wires, i dont' know what to connect them to:
Yellow wire: From DVD to "ACC (ignition switch)"
Blue wire: From DVD to "Remote Out"
If anyone needs the diagram i'll be more than happy to email it to them since i REALLY need to know where the 2 go to..i have an idea, but i keep blowing the fuse so i'm guessing i'm doing it wrong..thanks to all!!
Eddie
*ahem*doublepost!*ahem*
the remote out is normally used for external amps and accessories or your power antenna if you have one and you are replacing your factory deck
-unless it has a wired remote control, in that case this is the wire that its probably used with....
the yellow wire, is your turn on lead for the player, either hooked to your ignition so it comes on with the key, or hooked up to the factory stereo ignition lead
