Help! One Turn Signal Wont Work?!? | Ford Explorer Forums
greensport
Brazoria, TX
95 Sport
I haev a 95 sport and the rear passenger turn signal does not work.. ok so I know it is not the bulb since it just worked a minute ago but then stopped and i know it isnt the fuse. I have read on here of a multifuntion switch or something but i really dont have a clue where that is on my truck. I tried searching for it but it wont let me use multifuntion since it is too common or something. Well anyways I am just looking to fix this soon so if anyone could help I would really appreciate it. thanks
bulbs blow all the time.... Sure it didn't blow? I would replace it just to make sure
I just replaced it 2 times...
Got a voltmeter? Pull the bulb and socket, then check for power there when your buddy works the signals. Got power?, replace the bulb. Sometimes the filiment breaks , then "re-welds" itself together for a short period of time before it really breaks. No power? repost and we'll go from there...good luck.
Also, does the front blinker work? Is the dash light steady or fast when that side is switched on?
the front blinker works and the dash light is fast
also.. i dont have a voltmeter because i just moved up to college and everything it at my house except for my basic tools so i guess i will have to go pick one up
Either the bulb or socket is bad is where my betting money is going. I just got done dealing with a similar issue today fixing my boat trailer lights powered from my 94 EX. Check all the bulbs cause the brake and tailight work off the same circuit.
alright here is the deal now.... i went outside turned on the emergency flashers and the blinker worked. so then i cut them off and tried the blinker and it worked. so i drove it around the block and the blinker worked the whole time.... but i know later on tonight the damn things not going to work, so i dont know what to do?
Sounding more like the connection in the socket itself...hope you get it resovled.
