bakerbh
- May 27, 2011
- Bethesda, MD
A month ago my car would always not start at certain times in the day, nothing consistent. Mechanic thought it was the starter motor, so I got that replaced. It then happened again afterwords. It turns out that when I put it into park with the shifter, for some reason the transmission does not recognize that it is in Park. So when I go to start it next, it won't unless I fiddle around with it. Now it will only start in neutral. Also, it won't go into reverse from drive, I can only go into reverse after putting it in "park." How serious of a problem is this or might it just be something with the linkage?
Thanks in advance for the help,
Brian
Brian
