Help please!!!!! | Ford Explorer Forums
Help please!!!!!
Neekie
2007 XLT
HELP PLEASE!!!
I am Neekie and am new this forum but I need HELP!!!!
I have a 2007 Ford Explorer XLT and yesterday while driving I just lost power. The jeep engine was still on and running but when I pressed the accelerator (gas pedal) there was no power. The check engine light came on as well as the little wrench light, so I pulled over and turned the jeep off. After about ten minutes or so, I started the jeep and the power was restored however the check engine light still remained, the little wrench went off.
I went through some water that had settled from the rain but I can't imagine that would have damage something...
What could be the problem???
Could be a Throttle Position Sensor. Since you have the check engine light on, there is a code stored in the computer that can be read at mostly every auto parts store. Without this code it will be nearly impossible to diagnose the issue.
I had that happen to me turned out that I had "Throttle stuck open" and "Forced idle" codes which is why the wrench light came on and the car would only idle until I shut it off and reset things.
Welcome to the site
