Hello I need help. My tail lights and the license plates light won't work. All the other lights work. Checked all the fuses, everything is good. Bulbs are good too. Please help
Disconnect all lamps which do not work. Place headlamp switch in Parking Lights ON position. Measure voltage between inoperative lamps one at a time, between harness "hot" wire and ground. If voltage is found 10 V or more, repair circuit 1205 (black), the ground circuit.
If no voltage is found, repair circuits14 (brown) and 109 (violet/white), the two feed power to all park lamps and license lamps.
IMO, it is very unlikely that both 14 and 109 would go bad at the same time. Therefore I would go for a loss of the ground connection to the lamps which are out. It is possible to bite through the insulation of the black wires feeding those lamps, solder a wire onto them, and connect it to the body nearby to effect a new ground. imp
