reconnell
- July 29, 2001
- Akron, OH
- '94 Explorer Sport
RE: 94 Explorer Sport
For about the last 6 months, I have had problems with starts. When I crank the engine after it has sat approximately 10-15 minutes, after I have been running it (e.g., starting the engine after coming out from the grocery store), the engine sputters and sometimes cuts off. The engine sputters for about 1-2 minutes before the rpm's even out. No problems with cold starts or with warm starts immediately after shutting the engine off.
I noticed similar stories on this message board that were reported as temperature sensor problems. I took my Explorer in to the shop today. They said the temp. sensor checked out fine. They said it is either the fuel injectors needing to be cleaned or a problem with the fuel pump. (I have been told these are the best mechanics around this area). They recommended starting with the injectors, then moving to the fuel pump if that didn't help.
Your feedback would be appreciated!
Robert
Robert
