George W
- March 25, 2009
- NH
- 2002 Ford Ranger Edge 4X4
Hell
n my 2002 Ford Ranger. This summer I lost a tranny cooler line ( a rusty spot on the line right next to the cooler hose ).I made it to the parts store replaced the bad part of the line with hose long enough to slip into the cooler on each side. I filled the tranny with Mercon V, (Napa brand).. all was fine till yesterday.. OD light flashes, slips in D and very slow going in R to the point it almost don't. If I let it sit for a min. and she will kind a slid into R.. I didn't hook up a code reader but to me mine feels fluid starved.. I wonder if I crushed the cooler line when I tightened the hose clamps I installed two clamps on each end of the line( I didn't want the hose to slip off. replacing the hose going to the cooler I did both when I was under there.. The tranny never gave me a issue of any kind before this and was 100% after I replace the cooler hoses back a in the fall.. I have about 126000 on the truck.. Fluid is clean and full. in fact I added a tad more just to see if there was a diffidence.. OK Band adj. I can get to the front most band but for the heck of me I could not get to the band that rear most it's rusted .. I have it lubed up now so that should help.. Could some one tell be what the front most band does and what the rear most band does? Could I just adj, the front most band and luck out? Please help!! My wife already put down money on a 2007 Toyota 4X4. D day is end of tomorrow to fix this Ranger.. We just sunk 500 bucks on new rotors brakes brake lines and ABS sensor...PLEASE HELP!! George
