LVExp
- March 8, 2008
- '96 5.0 XLT
After much testing with manifold gauge and I’ve dye I found the leak in the evaporator. While I was at it I figure I would replace the accumulator since it was starting to rust and only $18 from RockAuto.
Got everything put together and did a vacuum test. Got to -25PSI. After removing the manifold gauge and waiting an hour it was back to 0. Draw it down to -25PSI again and this time when I removed the manifold gauge connector from the low pressure test port I heard a noise. Put my finger over the port and felt suction.
Held my finger over it for 10 min and it kept the vacuum at -25PSI. Removed my finger and it was back to 0 PSI in a few minutes.
Ok so schrader valve is bad, it happens. Off to AutoZone for another accumulator. Hooked it up, same exact issue. Low pressure test port is leaking under vacuum. Tried installing the cap but it’s not tight enough to hold pressure.
Did I do something wrong to have two do the same exact thing? Will it be different when it’s under positive pressure? I don’t want to waste the $ charging it to see or venting the refrigerant.
Ideas?
Ideas?
