Help with part identifications? | Ford Explorer Forums
dsfii93sport
Indy, IN
93 Sport
Help with part identifications:
Can someone tell me the correct name for these parts so I can go buy them! :)
First on regular cars I know the name of this ball joint that comes from the steering linkage to the hub is the outer tie rod end. Is the the same name on the 4x4 truck? The ball joint that connect the steering to the hub is named.........?
And,, what is the name of the ball joint that is in the middle of the two steering arms that connects them both together?
Thanks a lot...
Yes, that first one is a tie rod end.
I can't quite picture the second one you are describing........... :)
Maybe it is the inner tie rod ends? It is the joint on the inner side of the tie rods.
