- February 16, 2001
- 43°48′48″N 91°13′59″W
- 91 4 do'
I ordered the Skyjacker steering stabilizer back in Sept and liked it. Then I ditched the Superlift sway bar drop brackets for the skyjackers and when i ran 2 skyjacker components together it did not work. I called skyjacker and explained that their system of mounting the bracket to the framerail and having the stabilizer hanging out there cause the outer end of the shock to bend and will eventually break so I removed the stabilizer. He said I could drill new hole further back in my frame, but I think this will bind up, and will also be back too far. I wish i had brackets like the duff or rancho. Any suggestions either on an easy homemade bracket to go under the motor or where to get the bracket for cheap. I was thinking maybe drilling a hole in a piece of Angle iron, but don't know if it will bend out if I dont set it up exactly correct.
Thanks
Thanks
