Help | Ford Explorer Forums
Help
speedie
UK
1998 Explorer
We got an explorer a week ago it's a 1998 auto matic
today on the way home from work the self leveling suspesion light came on after about 10 miles after I had stopped and re started the engine it went off for another 10 miles then I had to stop again as a female travelling alone on country lanes I don't really want to keep stopping does any-one know whats wrong and how to fix it
Thanks
:confused:
Jill
Jill, there's no need to panic! And there's no need to stop and switch off the engine when the warning light comes on. The warning light may seem alarming but there is nothing to worry about. Nothing catastrophic is about to happen. The warning light is coming on to let you know that there is a 'fault' in self levelling system and that the computer has switched it off. I can't help you find the fault (there is soooo much that can go wrong with the self levelling system) but I can assure you that you can drive your Explorer normally without any noticable problems. I had a '98 Ex with the symptoms you describe. I had it for over 3 years and spent about £400 trying to fix it but it was money down the drain...
Yours doesn't happen to be reg No. S 138 LFL by any chance?
Hope this helps,
Simon H
Jill???
