H i all need some help what is it the rod right behind rear wheel looks like tie rod end on a 2005 Explorer rubber bushing torn need new one what is that part called also can i change upper ball joint in the back or do i need new control arm thank you for all the help.
Rockauto has the complete rear upper control arm listed for $135. I don't see a listing for a sperate rear ball joint.
The other part you are describing is called a rear toe link. From what I understand, it is a dealer only item. I know Autozone, and RockAuto don't carry them.
After changing either one or both of these, you will also need a 4 wheel alignment.
