help | Ford Explorer Forums
help
kissman13
usa
2002 ford sport trak
my 2002 ford sport trak 2 wheel drive seems to be wanting to stall when idoling,transmission fluid is low,i cant find where to add fluid,would that be the problem?
welcome kissman
You add fluid to where the dipstick is. I seriously doubt thats your problem though. Sounds like a fuel or spark issue. This could be many many things.
welcome to the forum. I will tell you the first thing I tell everybody- Use the search bar and you are bound to find someone else has had similar issues and it will give you a place to start. GOOD LUCK
Welcome!
I had a similar problem but with my 93' ex and it was because I had a hole in my vacuum hose so the car would die if i didn't keep the rpm's up every time I was stopped. But there was a pretty distinct hissing noise when the car was on.
