hesitaion after spark plug and wire change | Ford Explorer Forums
Blrob5
North Haven, CT
91 XLT
Just changed plugs and wires, as well as pcv valve. Started the truck and felt like it was hesitating, although it held rpm's around 6000. Prior to changing plugs and wires, ran smooth. I'm thinking maybe one of the wires isn't seated on the plug properly. When taking off the old plugs, broke two of them(the ceramic part), at the one and two cylinders. Managed to get them out with no problem. Any suggestions?
Thanks, Rob
Disconect your negative for 30 min and then let your engine idle for like 15 min. The computer probibly needs to reset itself or you gapped the plugs wrong. Same thing happened to me on my 91.
Are you sure you don't have some wire's crossed?
