Hey there new with lots of questions :) | Ford Explorer Forums
Giant19000
Hey guys Ive been looking at this site for quite a while now and hope to learn all i can!! I currently have or have had my 98 ford explorer Eddie Bauer v6 with a 2004 ford explorer engine..I just startedhaving this problem yest. Where my passcode for drivers side won't work to unlock/lock door, or even when I'm inside and try to lock/unlock the doors with the button on both drivers and passengers side,now my windows work and anytime I try the passcode the lights turn on but won't unlock and I was wondering can anyone pls help mr with this ?and if j can't do it myself how much am I looking to spend???thanks in advance guys.
Welcome! I'd take it to your local mechanic to see what the issue is, or use the search button and see what happens
Try the factory preset code, its a pain to get to but its worth a shot. 1995 thru 2001 is located in the jack storage compartment in the rear of your Explorer. First remove the panel to the jack storage compartment. Towards the front of this area you should see a metal box this is your auto-lock module(way up front next to your rear left passenger seat). On the back side of this is your 5 digit code factory preset code. It is hard to get to. To see it you will have to loosen, pull, use a flashlight or a mirror but it can be done.
2002 thru 2007 is in the right panel behind the middle row window. It is below the seat belt mechanism. You have to pull out the top plastic panel off, then loosen the lower panel to be able to see the face of the computer module. The code is on a sticker on the face of the module.
