ancientcityRRT
- June 22, 2014
- Tampa, FL
- 2000 Explorer XLT
...new guy here. I just bought a 2000 XLT and I like it so far. There are a few things I'm going to do as the new owner like change the oil and tranny fluid, etc., but there a also a couple things I'd like to fix that aren't just maintenance related.
1. Driver's side door lock - All of the door locks work with either the fob or the lock switch except for the driver's door. It moves when you hit either the fob or switch, but doesn't engage. I have to lock/unlock it manually. Maybe just a linkage getting hung up or that is disconnected?
2. Side mirror switch - fuse is good, so I guess either the switch or a broken wire. Does it just pop into place or will I have to dig under the dash to get it out?
3. The gas gauge and temperature gauge don't "zero out" when the key is turned off. They work fine, and reset when you crank the truck back up, but they stay up when the key is off. Not a must-do fix, but it just kinda bugs me.
I'm also going to change out the stereo, which is easy enough, but I was wondering if you guys might have a favorite car stereo site or DIY resources for auto electronics. Thanks!
