hi wanna run stock 15s. 10 hole i think there called | Ford Explorer Forums
duggyd123
delphi in
95 xlt, 97 eddie bauer,79
i would like to know what is the biggest tires i can run on these rims. i love these rims and am going to be powder coating them black. i would like to run a 31 or 32 what brand tire can i run etc.
edit they arent 10 holes they are the ones with 10 diagnal shapes in them.
look in the 8th posts pics in the following post
http://www.explorerforum.com/forums/showthread.php?t=99356
oh and to let everyone know i am doing a 2in suspension lift and 3 in body
The biggest tire that will (safely) fit on a stock 15" would be a 33x10.50, which is tall but narrow, and what will probably fit with a 2 in suspension and 2 or 3 in body lift.
31x10.50 will fit on a stock truck, no lift needed.
32x10.50 might rub without lift, but a small torsion twist and shackles/AAL in the rear will take care of that, or just a 2 inch body lift.
Gearing matters a lot when going up in tire size. If you put on larger tires, but have high factory gears, the ride is gonna be slow and the engine will bog down a lot.
It's easiest to just go with 31's on stock 15's until you can do the gears, lift and big tires all at once.
