I think you need to re-examine what you're talking about.
Standard stock halogen bulbs consume 55 watts, which draws about 4.6 amps. The fuses on the headlight circuits in the Explorer are 10 amps for each headlight. The wiring running from the fuses in the BJB (battery junction box) to the headlights is 18 gauge (red with black stripe, in case you care to check), which in automotive applications is rated for 16 amps continuous usage (reference
AWG chart).
The HID ballasts are stated to consume 35 watts each, which is a current draw of 2.9 amps. This is less than the 4.6 amp draw of the factory halogen lights.
However, at startup, the ballasts do draw quite a bit more current. Immediately at startup, each ballast draws 7.2 amps, or 86 watts. This increases rapidly until it peaks at about 8.6 amps 5 seconds after startup. At this point it rapidly decreases over the next 20-25 seconds, until it stabilizes at around 3.4 amps, which is 40 watts. This is a bit more than the 35 watts they claim, but considerably less than the 55 watts the factory system is designed to supply.
At no time do the ballasts draw more than the factory headlight wiring is designed to supply. The simple fact that the fuses do not blow when the lights are used is proof of this.
If you'd like to see an actual demonstration of HID ballast current draw, have a look at
this video.
