87xjmike
- May 11, 2015
- Colfax, ca
- 93 exploder
1993 5spd 4wd expo
My motor started at around 1350-1400 when I first fired up the rebuild and after 3 hours of run time she sticks to a 1k rpm idle speed. When I release the clutch to take off it goes back down to ~750 on take off from a stop.
What should the voltage and ohms be to anD from the coolant temp sensor? And does anybody know what pin it is at the PCM?
I can't seem to get a solid reading and fear either my PCM is ####ed or I'm testing the cts wrong as its hard to get to. After I siezed my motor in a water crossing, I had to rebuild it and the tranny. The water never got higher than the lower part of the grill on the bumper. The carpet got a little squishy wet, but no water was splashing around above the carpet.
I've checked for vac leaks- she pulls a solid 25 on a vac gauge at a 1200 rpm idle, it goes down to, 10-15 when I Rev it so I'm pulling a good vacuum from my vac tree on the back of the intake.
Cts/ect is new and ran good before the rebuild
I connected my ford specific obd1 tester and it said 111=system ok, then a 30. The book goes from 29 and humps to 31 skipping 30. So is 30 a real code? If not that's why I fear my PCM is going kaput
I tested the TpS and it's good
I swapped in a known good maf
Sprayed carb cleaner everywhere
No change in idle when I disco the IAC- I did take it apart and clean it and changed the gasket.
My rebuilt motor runs great otherwise, this high idle is just bugging me.
Thanks in advance for any help.
