grn93
- March 6, 2005
- Maple Ridge B.C.
- 93 XLT
Hello there...........just joined the forum, hope you can help me with my problem. I have a 93 Explorer with the 4.0 litre engine, auto tranny. I took the engine down to the block, had the heads hot tanked and a whole new valve train installed after a valve job. Put the truck back together and it fired right up however it idles around 1200 rpm now. When you put it into gear, it revs high for a second then it drops down to about 850 which is about where it should be idleing when in park or neutral. I have tried adjusting the screw on the throttle linkage near the throttle body, checked all my vacuum lines and everything seems fine. Any idea as to why it is idleing so high and how I can set it lower. Thanks.
Ian
Ian
