High pitch noise on engine side. | Ford Explorer Forums
itamnala
2002 Explorer Sport Trac
Hi Guys,
Good day! I'm a newbie here and just bought an Explorer Sport Trac 2002 with 62thou km reading on it last week. The problem is, when the engine is running in idle, there is a high pitch sound coming from the engine bay. As the engine rpm goes up, the high pitch sound becomes stronger. It's like two tin metals rubbing each other.
I can't figure out exactly where it is coming from but I suspect the belt or the auto tensioner as the possible culprits. I am quite sure it is not from the engine itself.
Any help from anybody would be much appreciated. Thanking you all in advance.
welcome
welcome try replacing idle air control unit its on driver side of upper intake part is like $40 at pep boys and is usually the cause of this noise
Thank you guys for the inputs and warm welcome. Rest assured all will be taken into consideration.
yea that happened to my 99 and thats wut it was. =p that noise is soooo annoying
