Hix's Truck.... :D | Ford Explorer Forums
Hix's Truck.... :D
rpenner54
Moderator Emeritus
Moderator Emeritus
Wichita KS
98 Merc
Sorry it took so long!
View
View
View
__________________
HIX
SuperCab 4x4
"Put the hammer down, she likes it rough!"
THANKS RYAN!
I was wondering what was going on! They are the same style of rims and tires I had on the Exploder. But they are new. Now all I need to is ilft the rear a bit.
ya...thats red! looks good though!
now..i noticed that you name wasn't on the list for the attica run....are you not coming now?! what the dilly yo?
The tires are 33s.
As far as Attica goes...B/c the turbo on my other car cost me my play money I will be sticking around Denver for a while.
Oh...by the way the truck is just Dirty...It is in great shape. Not that you can tell from the pics!
I am using a 5.5 in Superlift from a Explorer in the front and 3 inch add-a-leaf in the rear. The rear is sitting a little low so I will be adding some extended shackles in a week or so.
looks good
Hey hix I just wanted to say that the truck looks great, I am pretty sure I saw it about a month ago, I was in Denver with a freind and I swear I saw it down by the new stadium, anyway it looks great!
here are a few pics of the truck after I flared the bed sides.
View
View
View
So how did you flare them, and how much further do they stick out?
I only flared them 1.5 inches. You can flare them up to 3inches.
If you look at the inside of the wheelwell you see a panel spreading the bed side from the bed and supports holding the bottom out. Cut a line thru the spreader and use a scissor jack to spread the fender out the desired amount. then extend the supports by the same amount by ubolting them, cutting them in half and welding some angle in there to spread em. If you go more than what I did the re is a seam near the tailgate you'll need to cut as well.
Here is a link that shows some of the procedure. From start to end it took me 4 hrs to do both sides.
Dead Link Removed
hey can you post some flex pics ?
