hole in my front differential | Ford Explorer Forums
shinta
yuma az
92ex
so after a good day of runnin thro the sand i get to the house and discover fluid dripping from the top of my front differential. upon investigating i discover a nice size hole in the top. any suggestions. oh yeah so i go to pull the ex into the garage and no it wont start. so it tries to turn over but wont. after reading some posts iam gonna try to change my throttle postion sensor and maybe my idle air control valve. again any suggestions.
you should get a better drop bracket but you could extend ur bumpstops
yeah i forgot to put the bumbstops on. where could i find a different drop bracket
The drop brackets are hard to come by separatly. You have to go to a dealer (superlift-james duff ect) and tell them it is a replacement for a wrecked vehicle or it is very hard to get one.
It's not hard at all....
You can find the pieces you need on eBay....Tuff Country Hardware is available seperately.
But you need to beef them up a little, welding some gussets in the known weak areas..
Info can be found here and on TheRangerStation on where to add them.
Ryan
