How and how much? | Ford Explorer Forums
How and how much?
hawaiianexp00
Nevada Transplant
Fallon, NV
2000 XLT
I need to change my coolant how do i drain it and how much do i need to replace it with? p.s. i got a little bit of muddy water in there so it's not too green anymore.
there is a drain **** at the botton, it looks like a wingnut.... dump in a bottle of antifreeze, then fill the rest with water.....
Good idea to use distilled water and mix 50/50 with antifreeze.
This link may be helpful:
Dead Link Removed
How much does antifreeze cost???
Maybe $5/gal You might need 1.5 gal
mix 50/50
I usually use 1 gal Antifreeze & slightly less than 1 gal distilled water. Total capacity should be slightly less than 8 quarts (2 gal).
Antifreeze in my local store is between $5 and $7 per gal depending on brand. Distilled water is about $1 per gal.
