How can I move my Ex with engine partially out? | Ford Explorer Forums
Vette76
Maine
02 XLT 4.0L & 97 XLT 5.0L
Hey guys. I apologize for asking this, as I saw this months ago but never realized that I would need to deal with this myself :)
I pulled my 02 in the garage and unfortunately put it into park. Now that I have the right side of the engine basically torn down and most of the fuel system and electronics disassembled, I need to move the Ex so that I can get enough room in order to get the engine hoist in front of it.
I believe someone mentioned that I would need to remove the fuse(s) for the fuel pump and fuel relay as well as reattaching both of the battery cables (as long as I still have the computer installed, which I do).
If this is correct, could someone also identify what numbered position of each of the fuses are as well? I bought a Haynes manual and it 'conveniently' does not include a sketch of the fuses.
Thanks!
Why not climb under the truck and pull the gear selector cable off, and flip the trans selector around until you find neutral?
I did this multiple times while changing the trans in my truck.
just jack it up with a floor jack or two or 4 and move it. I have some snow mobile dollies that I use for heavy stuff but never tried on an ex.
